pepino7
(pepino7)
1
Hi all,
During my installation I have this message
Yet I have php version 5.1.3
I do not understand
To run Piwik you need at least PHP version 5.1.3
Unfortunately it seems your webserver is using PHP version 4.4.3-dev.
Please try to update your PHP version, Piwik is really worth it! Nowadays most web hosts support PHP 5.1.3.
Pleaz help thx !
ts77
(Thomas Seifert)
2
Well, even if you “have” php-5.1.3 your webserver doesn’t use it.
Contact your host about it.
pepino7
(pepino7)
3
So I will contact my hote.
Thx
pepino7
(pepino7)
4
When I want Access and manage my MySQL database i can see that :
MySQL
* Serveur: mybesite.sql.free.fr via TCP/IP
* Version du serveur: 5.0.83
* Jeu de caractères pour MySQL: UTF-8 Unicode (utf8)
Serveur web
* Apache
* Version du client MySQL: 5.1.35
* Extension PHP: mysql
phpMyAdmin
* Version: 3.1.5
Where is the problem ?
Thx more
vipsoft
(vipsoft)
5
Your web server defaults to PHP4. Contact your hosting provider – it’s often a .htaccess change in order to use PHP5.
There are some examples in the FAQ. http://piwik.org/faq/how-to-install/#faq_77
Note: those examples are specific to the hosting provider.
pepino7
(pepino7)
6
I create the htaccess file with the code A, B and C and is still in erro
pepino7
(pepino7)
8
ok style_emoticons/<#EMO_DIR#>/wink.gif
pepino7
(pepino7)
9
I contacted my hosting provider and this is their response :
Dear
I regret to inform you that we are unable to respond to your request, because it is outside support for the technical team of Free.
So, I still can not install piwik
vipsoft
(vipsoft)
10
I didn’t get go past high-school French, but a Google search for “php5 free.fr” appears to suggest that an .htaccess file with “php 1” works.
