Call to tracking code blocks webserver
#1
after upgrading from version 2.5.0 to 2.6.1 (automatic update) I realized some problems if a user entered the site I want to track. Piwik is located under another domain than the tracked site.
If a user entered the tracked site and the tracking url is called, piwik does not respond. The call seems to hang forever.
There is no load on the webserver where piwik is located, webserver/php process does noting. This call blocks the webserver for all other calls, clients are waiting for responses from webserver forever. I have to restart the webserver manually.
Even if I entered the image tracking url manually in the browser (piwik.php?idsite=1&rec=1), the problem is the same.
The strange thing is, sometimes its working but most of the time not.
After piwik update there were no errors in the log. If tracking url is called, there are also no errors.
I also tried a fresh and clean install of piwik 2.6.1 and the problem still exists (also tried beta 2.7).
For piwik I’m using debian wheezy with lighttpd 1.4.31, PHP 5.5.16 and mysql 5.5.38.
The dashboard of piwik itself works as expected, no problems there.
Any ideas what the problem might be?
regards
Alex
(Matthieu Aubry) #2
Can you try to setup: How to Set up Auto-Archiving of Your Reports - Analytics Platform - Matomo maybe it solves the issue?
Otherwise I don’t know what could cause this random slowness…strange!
#3
Hi Matt,
thanks for your reply. Yes indeed, setting up auto-archiving as cronjob solved the issue GREAT :slight_smile:
But why is the browser based archiving not working?
There are about 20 visits per day for the tracked site (not a large site :wink: ) and visits are deleted after one year. db size is about 25 mb.
Alex
(Matthieu Aubry) #4
There are about 20 visits per day for the tracked site (not a large site winking smiley ) and visits are deleted after one year. db size is about 25 mb.
That’s a very good question, i would like to know why it didn’t work in your case. if you get more informatio or some error in webserver error log let us know!
