Unipik
#1
Hello Community;
I just installed piwik via softaculous, but in branding settings i get the next warning: http://gbits.net/fIPX
The peculiar thing is that in the indicated directories there not any logo; look : http://gbits.net/ymhs ; the logo is in image directory.
It is an installation problem, database problem?, Appreciate their contributions to solve this issue.
Regards,
Unipik
matthieu
(Matthieu Aubry)
#2
Give permission to Piwik to write in the themes/ directory
Unipik
#3
Hi;
Folder permissions are 755 and file permissions are 644 as standard in piwik instalattion.
Apparently it’s a problem of the database, as my hosting uses MariaDB and are not compatible with piwik 100% (only MySQL)
matthieu
(Matthieu Aubry)
#4
MariaDB is compatible with Piwik 100% as far as we know
Unipik
#5
Problem resolved, in PHP configuration (cpanel) “upload file” was of; now is on and works fine.
About MariaDB, present the next error : Screenshot on 10.24.2013 at 12.47.34 PM.png • Droplr™ , say “The used command is not allowed with this MariaDB version[42000]”
What should I do with this warning ?
Thanks,
Unipik.
