I have several accounts that are either toggled for weekly email reports or monthly and they are not being automatically sent out.
Are you using How to Set up Auto-Archiving of Your Reports - Analytics Platform - Matomo
If not, please comment in: Regressed: Scheduled reports should be sent automatically by webcron, when cron is not setup · Issue #4612 · matomo-org/matomo · GitHub
Yes, I am using 2.03.
Have you setup the cron as per: How to Set up Auto-Archiving of Your Reports - Analytics Platform - Matomo
I have never done that before and it worked just fine before.
Ok, so you are experiencing this bug: Regressed: Scheduled reports should be sent automatically by webcron, when cron is not setup · Issue #4612 · matomo-org/matomo · GitHub
we’ll get it fixed asap!
Ok, great…what do I need to do?
Ok, I will wait…I am kind of dumb when it comes to code stuff.
[attachment 1612 cron.jpg]Ok, I did a clean install and just updated 2.1…I still have no idea how to setup the cron…here is a snag of my Mediatemple hosting screen.
Mediatemple cron > command to execute: try
/usr/bin/php5 /path/to/piwik/misc/cron/archive.php --url=http://example.org/piwik/
replacing by your server path and Piwik URL
Ok, I think I am making progress…I got a gillion of these error messages this morning…
Warning: Invalid argument supplied for foreach() in /nfs/c04/h02/mnt/64371/domains/mydomain.com/html/nsmanalytics/core/CliMulti.php on line 176
Same Problem here.
I got this error few times every cronjob.
Have you fix it?
which errors do you get exactly?
[quote=matt]
which errors do you get exactly?[/quote]
I posted my exact error above. But, literally I am getting the same error message maybe 50+ times in the same email.
We get:
PHP Warning: Invalid argument supplied for foreach() in /[piwikdir]/core/CliMulti.php on line 176
This error is X times in every email.
X = 2 - 100
Thanks for the report! can you please try apply this patch: This may fix the bug: PHP Warning: Invalid argument supplied for fore… · matomo-org/matomo@4ec3413 · GitHub
If it does not fix it still, let me know, cheers
Yes, the patch fixed it!
Ok, the patch almost fixed it…I only got one error this morning…BUT, auto reports are still not being sent. I have two accounts that are triggered for weekly and nothing went out today.
What error did you get?
