First of all thanks a lot for this great piece of software. I think Piwik is a great alternative to Google Analytics.
The installation works without any problems and I’m collected some data. Then I wanted to set up auto-archiving, edited the .sh file and manualy executed it. It seems to be that it works in generall, but when I execute it over the shell I get a lot of (translation errors?) warnings:
Warning: Invalid argument supplied for foreach() in /var/www/vhosts/mydomainname.com/httpdocs/piwik/plugins/LanguagesManager/API.php on line 34
Backtrace -->#0 Piwik_ErrorHandler(2, Invalid argument supplied for foreach(), /var/www/vhosts/mydomainname.com/httpdocs/piwik/plugins/LanguagesManager/API.php, 34, Array ([languages] => ,[languageNames] => Array ())) called at [/var/www/vhosts/mydomainname.com/httpdocs/piwik/plugins/LanguagesManager/API.php:34]
#1 Piwik_LanguagesManager_API::getAvailableLanguages() called at [/var/www/vhosts/mydomainname.com/httpdocs/piwik/plugins/LanguagesManager/LanguagesManager.php:100]
#2 Piwik_LanguagesManager::getLanguageCodeForCurrentUser() called at [/var/www/vhosts/mydomainname.com/httpdocs/piwik/plugins/LanguagesManager/LanguagesManager.php:52]
#3 Piwik_LanguagesManager->getLanguageToLoad(Event_Notification Object ([_notificationName] => Translate.getLanguageToLoad,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0)) called at [(null):0]
#4 call_user_func_array(Array ([0] => Piwik_LanguagesManager Object (),[1] => getLanguageToLoad), Array ([0] => Event_Notification Object ([_notificationName] => Translate.getLanguageToLoad,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0))) called at [/var/www/vhosts/mydomainname.com/httpdocs/piwik/libs/Event/Dispatcher.php:280]
#5 Event_Dispatcher->postNotification(Event_Notification Object ([_notificationName] => Translate.getLanguageToLoad,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0), 1, ) called at [/var/www/vhosts/mydomainname.com/httpdocs/piwik/libs/Event/Dispatcher.php:250]
#6 Event_Dispatcher->post(, Translate.getLanguageToLoad, Array (), 1, ) called at [/var/www/vhosts/mydomainname.com/httpdocs/piwik/core/PluginsManager.php:487]
#7 Piwik_PostEvent(Translate.getLanguageToLoad, ) called at [/var/www/vhosts/mydomainname.com/httpdocs/piwik/core/Translate.php:72]
#8 Piwik_Translate->getLanguageToLoad() called at [/var/www/vhosts/mydomainname.com/httpdocs/piwik/core/Translate.php:43]
#9 Piwik_Translate->loadUserTranslation() called at [/var/www/vhosts/mydomainname.com/httpdocs/piwik/core/FrontController.php:236]
#10 Piwik_FrontController->init() called at [/var/www/vhosts/mydomainname.com/httpdocs/piwik/index.php:51]
Does anyone know how to fix this? Or is this normal because I don’t have colected enough data (as I said this is my first day)?
Any help would be nice style_emoticons/<#EMO_DIR#>/smile.gif
Best regards,
Andy
