Archive process errors/warnings
after some upgrade to the server Piwik is running on we started getting an email from the cron job running the archive
It is filled with indications that seem to be warnings but:
  1. Are really alot
  2. Just fill the email for nothing
PHP Deprecated: Comments starting with ‘#’ are deprecated in /etc/php5/cli/conf.d/mcrypt.ini on line 1 in Unknown on line 0
Is there a way to avoid this? Is this really a warning?
Thanks,
Arie
It seems you have updated your version of PHP.
If you read PHP: Deprecated features in PHP 5.3.x - Manual you can learn that
You need to update your ini files.
Thanks i made the change and the warning is gone.
