When I run:
/usr/bin/php5 /home/anton/data/www/stat.my_domain.org/html/misc/cron/archive.php -- url=http://stat.my_domain.org/ >> /home/anton/data/www/stat.my_domain.org/piwik-archive.log
output is:
Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=244&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=293&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=303&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
313 total errors during this script execution, please investigate and try and fix these errors
ERROR: 313 total errors during this script execution, please investigate and try and fix these errors. First error was: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=1&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check your
PHP Fatal error: 313 total errors during this script execution, please investigate and try and fix these errors. First error was: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=1&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check your in /home/anton/data/www/stat.my_domain.org/html/misc/cron/archive.php on line 573
in /home/anton/data/www/stat.my_domain.org/piwik-archive.log file:
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=309&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=310&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=311&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=312&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=313&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=87&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check you
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=92&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check you
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=223&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=232&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=244&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=293&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
[2013-06-07 05:38:42] [4e3b3724] Error: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=303&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check yo
[2013-06-07 05:38:42] [4e3b3724] 313 total errors during this script execution, please investigate and try and fix these errors
[2013-06-07 05:38:42] [4e3b3724] ERROR: 313 total errors during this script execution, please investigate and try and fix these errors. First error was: Got invalid response from API request: http://stat.my_domain.org/index.php?module=API&method=VisitsSummary.getVisits&idSite=1&period=day&date=last52&format=php&token_auth=4604cbe64b9dde47306b6031ea23af9f&trigger=archivephp. The response was empty. This usually means a server error. This solution to this error is generally to increase the value of 'memory_limit' in your php.ini file. Please check your
in error.log:
[Fri Jun 07 09:38:42 2013] [error] [client 31.186.96.202] PHP Parse error: syntax error, unexpected T_FUNCTION, expecting ')' in /home/anton/data/www/stat.my_domain.org/html/core/Archive/DataTableFactory.php on line 290
# php --version
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20090626/suhosin.so' - /usr/lib/php5/20090626/suhosin.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP 5.3.22-1~dotdeb.0 with Suhosin-Patch (cli) (built: Mar 2 2013 23:12:49)
Copyright (c) 1997-2013 The PHP Group
Zend Engine v2.3.0, Copyright (c) 1998-2013 Zend Technologies
with Zend Optimizer+ v4.1, Copyright (c) 1999-2010, by Zend Technologies
# service mysql status
[info] /usr/bin/mysqladmin Ver 8.42 Distrib 5.1.66, for debian-linux-gnu on x86_64
Copyright (c) 2000, 2012, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Server version 5.1.66-0+squeeze1-log
Protocol version 10
Connection Localhost via UNIX socket
UNIX socket /var/run/mysqld/mysqld.sock
Uptime: 83 days 20 hours 55 min 42 sec
Threads: 7 Questions: 2293649129 Slow queries: 112851 Opens: 3564523 Flush tables: 1 Open tables: 18372 Queries per second avg: 316.516.
