We have some weird effects in our matomo reports when we use segments. I can reproduce the underlying problem using the API, where I’m getting inconsistent results using different periods.
I get expected results when i use period=month
query:
index.php?module=API&method=Actions.getPageUrls&token_auth=...&idSite=1&date=20170101&segment=pageUrl%3D@tirol.gv.at%252Fschwaz%252F&period=month
result:
<?xml version="1.0" encoding="utf-8" ?>
<result>
<row>
<label>schwaz</label>
<nb_visits>9263</nb_visits>
<nb_hits>10437</nb_hits>
<sum_time_spent>212838</sum_time_spent>
<nb_hits_following_search>660</nb_hits_following_search>
<sum_bandwidth>177068676</sum_bandwidth>
<nb_hits_with_bandwidth>10018</nb_hits_with_bandwidth>
<min_bandwidth>29423791</min_bandwidth>
<max_bandwidth>38628250</max_bandwidth>
<entry_nb_visits>3269</entry_nb_visits>
<entry_nb_actions>15929</entry_nb_actions>
<entry_sum_visit_length>556495</entry_sum_visit_length>
<entry_bounce_count>1462</entry_bounce_count>
<exit_nb_visits>2928</exit_nb_visits>
<avg_bandwidth>17675</avg_bandwidth>
<avg_time_on_page>20</avg_time_on_page>
<bounce_rate>45%</bounce_rate>
<exit_rate>32%</exit_rate>
<idsubdatatable>1</idsubdatatable>
</row>
</result>
But following request using period=year gets an empty result:
query:
index.php?module=API&method=Actions.getPageUrls&token_auth=...&idSite=1&date=20170101&segment=pageUrl%3D@tirol.gv.at%252Fschwaz%252F&period=year`
Result:
<result />
How is that possible? Any hints how I can dig into this?
Thanks for your help.
