Api Call with range filter receives less data in larger time span
When I filter my events from 2025-10-10 to the 2025-10-27 I get more data then when I filter from 2025-10-01 to the 2025-10-27, in some date ranges I get even no values at all even though I get values in smaller ranges. I tried looking at the values with the day period and there are clearly values there. The problem happens with all my event api calls, though with some much less noticable. What could be the cause for this? (example of my api call below)
websiteUrl?token_auth=abcd1234567890&module=API&format=json&idSite=1&method=Events.getName&period=range&date=2025-10-10%2C2025-10-27&segment=actions%3E1&filter_column=label&filter_pattern=.*%22category%22%3A%22media%22&filter_limit=-1
