Trashy
February 10, 2011, 4:02pm
1
Piwik tracks clicks on downloads on its own pages. But if a user goes to e. g.
http://www.mysite.com/downloads/report007.pdf
from somewhere else or types in that URL directly in his browser, no Piwik-Javascript is loaded from anywhere. Consequently, this download is not tracked.
Are there any tricks zu make these downloads being tracked?
Thanks,
Peter
jlouis
February 10, 2011, 7:58pm
2
It’s even better than a trick because it’s a native function.
Go to Goals/Overview/Goal Management/Create a new goal, then Goal is Triggered when visitors download a file.
That could not be easier.
Jean Louis
Trashy
February 10, 2011, 9:27pm
3
This, sounds great, Jean. The problem is, it does not work. The goal behaves like the “downloads” statistic:
Clicks are tracked, direct downloads are not.
I would have wondered if it had worked. Piwik cannot access the webserver log files. Where else could Piwik recognize that file access?
Any other ideas anyone?
vipsoft
(vipsoft)
February 11, 2011, 4:31am
4
Use a proxy script to serve your downloads.
the proxy can be automatically injected with a .htaccess
