im on a shared webspace with ssh support. I try your import script to analyse my apache logs.
I get it to work, but there are sometime some “Fatal errors” and i have no idea why. It is, if i restart it without “skip” every time the same “skip-line”
Example:
4349 lines parsed, 85 lines recorded, 0 records/sec
Fatal error: Forbidden
You can restart the import of "/home/log/access_log_piwik" from the point it failed by specifying --skip=326 on the command line.
I try to figure out on what line these script end with that fata error, but i cant. If restart it at “skip=327” that it runs to the end and all works fine. Same problem is on some other access_logs “access_log_1.gz” and so on. But im not sure why it ends. If that is a misconfigured line in accesslog? Which line should i check?
Regards
