Hey there,
since we upgraded from latest 3.x Version to 4.x Version we get those Errors on all of our Web-Pages:
The method requireCookieConsent is registered more than once in "_paq" variable. Only the last call has an effect. Please have a look at the multiple Matomo trackers documentation: https://developer.matomo.org/guides/tracking-javascript-guide#multiple-piwik-trackers matomo.js:12:287
The method setTrackerUrl is registered more than once in "_paq" variable. Only the last call has an effect. Please have a look at the multiple Matomo trackers documentation: https://developer.matomo.org/guides/tracking-javascript-guide#multiple-piwik-trackers matomo.js:12:287
The method setSiteId is registered more than once in "_paq" variable. Only the last call has an effect. Please have a look at the multiple Matomo trackers documentation: https://developer.matomo.org/guides/tracking-javascript-guide#multiple-piwik-trackers matomo.js:12:287
The method enableLinkTracking is registered more than once in "_paq" variable. Only the last call has an effect. Please have a look at the multiple Matomo trackers documentation: https://developer.matomo.org/guides/tracking-javascript-guide#multiple-piwik-trackers matomo.js:12:287
We have always used the “Alternative solution” mentioned in the Docs: https://developer.matomo.org/guides/tracking-javascript-guide#multiple-piwik-trackers
And it was always working as expected. It’s still working - but some of our Customers are unsettled because of those Warnings …
Example: https://www.futureweb.at/ (after accepting Cookie Consent … otherwise it won’t track)
Code:
<script data-type="application/javascript" data-name="matomo">
_paq.push(['requireCookieConsent']);
_paq.push(["setDocumentTitle", document.domain + "/" + document.title]);
_paq.push(['trackPageView']);
_paq.push(['enableHeartBeatTimer']);
(function() {
var u="https://stats.futureweb.at/";
_paq.push(['addTracker', piwikUrl = u+'matomo.php', 927]);
g.type='text/javascript'; g.async=true; g.src=u+'matomo.js'; s.parentNode.insertBefore(g,s);
</script>
<noscript>
<p><img src="https://stats.futureweb.at/matomo.php?idsite=1&rec=1" style="border:0;" alt="" /></p>
<p><img src="https://stats.futureweb.at/matomo.php?idsite=927&rec=1" style="border:0;" alt="" /></p>
</noscript>
I guess this was changed in 4.x … but IMHO a Solution mentioned in the Docs should not throw Errors/Warnings?
Any idea how to disable those Warnings?
thx, bye from Austria
Andreas A.
