I get this message when i click on page visitors>custom variables; Action ‘index’ not found in the module ‘CustomVariables’.
but most important issue is i cant install any plugins, if i try then i get a message that says: The plugin ZIP file does not contain a subfolder, but Piwik expects plugin files to be within a subfolder in the Zip archive.
I’ve fixed the Custom Variable error by deleting the file: plugins/CustomVariables/Menu.php
I tried to click on a plugin in Settings > Marketplace in your piwik and got the error:
Failed to write cache file “/var/www/vhosts/xxx/httpdocs/stats/tmp/templates_c/1e/a1/3f66ac96653b6be6bd7e003555e8eab5bbfe49213594d5ff1c4c529c8be3.php”.
I really dont think its a permission problem, but dont mind making 100% sure,
can you pin point the exact file/folders that hand plugins and their manifest, and i will chmod them?
