2.3 - not possible to generate insights
#1
We are on piwik 2.3. I notice the following:
Movers and Shakers
It is not possible to generate insights for this date and period combination.
Insights Overview
whenever I select a date range. When I use one of the defined ranges, such as day, week, month or year,
these two areas are filled. Even if I pick a date range that matches the month, still does not populate. I
have not found anything that give any information on this. Is it not supposed to on a user defined date range?
Thanks,
Douglas
#2
There are only four possibilities for such a case:
  • Not enough permission to view the data
  • You are using period=range
  • You are using day=previousX
  • You are using day=lastX
As you mentioned you have selected a ‘range’ period which is currently not supported. The problem is that we cannot really compare the data to anything. Imagine you have selected a range period from “Dec 02 2013 - Dec 10 2013”. Do you want to compare to “Dec 02 2012 - Dec 10 2012”, “Dec 01 2013 - Dec 09 2013”, “Nov 02 2013 - Nov 10 2013” or “Nov 23 2013 - Dec 01 2013”? Surely it would be possible to implement to let you pick to which date you want to compare against but it’s a bit tricky and just didn’t make it into version 1. I’ll create a ticket for this but I can’t promise it’ll be implemented soon.
FYI: If anyone is interested related code is here: matomo/Range.php at master · matomo-org/matomo · GitHub
