2.2.2 generated (weekly) report AND manual report do not work any more
After upgrading 2days ago I realized that the expected weeky report didn’t arrive. Checked the settings and tried to send me a manual report or generate a download. Didn’t work:
This is the message I got (above the list with the reports):
API returned an error: Trying to add two strings values in DataTable\Row::sumRowArray: ‘0%’ + ‘100%’ at Row.php:581
Any Idea?
Thanks.
Theres a whole thread related to this.
Just curious what server environement and php version are you running?
Forgot link
http://forum.piwik.org/read.php?2,114885,115198#msg-115198
This is a known bug, we are right now working on a solution: Trying to add two strings values in DataTable\Row::sumRowArray · Issue #4706 · matomo-org/matomo · GitHub
Thank you for the link to the other thread.
I forgot to attach this information:
PHP version is 5.3.28
Apache/2.2.26 (Unix)
I hope this can help. If you need the full phpinfo, I can PM that.
Thanks.
I’m getting this error as well with 2.2.2. Let me know if you need my specific server details. I’m mostly commenting here so that I can have replies to this thread emailed to me when this issue is resolved.
Add your specs as user above as it could show a trend towards a config type that might help diagnose. Can you upgrade your php if its below 5.3.3?
Hello, This bug has been fixed in latest beta version: I would like to test early beta and RC releases, how do I enable automatic updates to use these development versions? - Analytics Platform - Matomo
Matt, the beta (2.2.3-b4) fixes it for me. Thanks!
Thanks! Beta 2.2.3-b6 fixed it also for me.
