1.9.2 upgrade and Piwik lost
After upgrade 1.9 > 1.9.2 I lost piwik.
Blank page
I tried every single thing found here with no result.
I re ftp the latest and unzip it iin shh. Then the setup or the piwik/ returns error 500.
(I kept my global and config ini files).
As read here if I delete the core/lic.log file, then the setup comes back to life and I can go 1 step further, delete again the lic.log until the DB step where returns a blank page.
Was not able to run the upgrade command in ssh (permission denied) if I chmod the index.php to 777 I got :
./index.php: line 1: ?php: No such file or directory
./index.php: line 2: /**: No such file or directory
./index.php: line 3: LEGALNOTICE: command not found
./index.php: line 4: LEGALNOTICE: command not found
./index.php: line 5: LEGALNOTICE: command not found
./index.php: line 6: LEGALNOTICE: command not found
./index.php: line 7: LEGALNOTICE: command not found
./index.php: line 8: LEGALNOTICE: command not found
./index.php: line 9: LEGALNOTICE: command not found
./index.php: line 10: config/: is a directory
./index.php: line 12: syntax error near unexpected token `'PIWIK_DOCUMENT_ROOT',
./index.php: line 12: `define('PIWIK_DOCUMENT_ROOT', dirname(__FILE__)=='/'?'':d
irname(__FILE__));'
rotation@ssh1:~/www/piwik$
I tried to reverse to previous (re ftp the zip after RM the whole piwik folder) the unzip it in ssh. Again error 500!
Really need help
Thank you
try downloading from here
https://github.com/piwik/piwik/archive/1.9.2.tar.gz
I reuse the official latest192.zip wish was supposed to be fixed since yesterday.
Looks like it’s ok again. The DB update occured and dashboard is back.
